5 Channel amps?
alxmlr789
6>5
I'm looking at switching up my setup a little bit and want to go witha 5 channel for my new ride.
What good 5 channels are there out there? I know of the Memphis belle, and the EDnine.5.. But looking for some more options.
I want it to have at least 700+ for the sub channel, and maybe 100x4+
Thanks guys.
The fosgate power 1000 will do it.
Front/Rear Channels
50W x 4 @ 4-Ohms RMS
100W x 4 @ 2-Ohms RMS
150W x 4 @ 1-Ohm RMS
200W x 2 @ 4-Ohms Bridged Mono
300 x 2W @ 2-Ohms Bridged Mono
Sub Channel
300W x 1 @ 4-Ohms RMS
600W x 1 @ 2-Ohms RMS
800W x 1 @ 1-Ohm RMS
Dimensions: 23" x 12.8" x 2.6" (58.42cm x 32.51cm)
I'm looking at switching up my setup a little bit and want to go witha 5 channel for my new ride. What good 5 channels are there out there? I know of the Memphis belle, and the EDnine.5.. But looking for some more options.
Thanks guys.
The thing about those 5 channel amps is that they are LARGE!
Memphis Belle - 25.81" x 7.6"
eD NINe.5 - 25.5" w/out ends or 27.125" w/ ends. x 10.65"
Rockford Power 1000 - 23" x 12.8"
DLS A7 - 23.82" x 9.45"
Audison LRx 5.1k - 21" x 7"
Zapco iForce I5100.7 (7 ch) - 24.5" x1 0.75"
More info on the Zapco: http://www.diymobileaudio.com/forum/showthread.php?t=42770
http://www.zapco.com/new/mainnewFrame.htm
4x55 @ 4 ohms
2X35 @ 4 ohms
1x450 @ 4 ohms
4x80 @ 2 ohms
2X45 @ 2 ohms
1X600 @ 2 ohms
2x180 @ 4 ohms
1x 80 @ 4 ohms
1x600 @ 2 ohms
MSRP-$823.00
With the type of power you are after two modest sized amps, a four channel and a mono sub amp, will fit in the same space. I am a BIG multi-channel amp fan but, I would recommend that you go with two amps if you can to reach that 1100 watt+ goal. The Eclipse ICEpower XA4200(100w x 4) and the ZA1200(1200w @ 2 Ohms) would be two nice choices. Can butt them together for a 24.4" x 10.1 footprint....and these are some of the most beautiful looking amps around and should be in the $300+ range each on ebay soon as they just became available.
Eclipse XA4200 - 12-3/16"x 10-1/4"
Alpine PDX - 10-1/8'' x 7-9/16''
Pioneer PRS - 11-15/16" x 7-11/16"
Kenwood Excelon - 13-5/16" x 9-3/8"
ARC Audio KS 300.4 - 13" x 8"
alxmlr789
6>5
alxmlr789
FL
WLDock
