First is an old and scratched 5 channel MTX. Cosmetically it has had way better days. It is missing 3 screws for the terminals. It still works 100% though. All channels power up fine. I am looking for $125 shipped OBO. Here are specs and pics.
Specifications
RMS Power measured at 12.5 Volts DC:Front & Rear:
25 watts x 2 into a 4 ohm load with less than 0.05% THD+N
50 watts x 2 into a 2 ohm load with less than 0.1% THD+N
100 watts bridged into a 4 ohm load with less than 0.1% THD+N
RMS Power measured at 12.5 Volts DC:Subwoofer
100 watts RMA into 4 Ohms with less than 0.3% Thd+N
200 watts RMS into 2 Ohms with less than 0.5% Thd+N
Dynamic Power* Front & Rear
65 watts x 2 into a 4 ohm load
125 watts x 2 into a 2 ohm load
250 watts bridged into a 4 ohm load
Dynamic Power* Subwoofer
150 watts x 1 into a 4 ohm load
300 watts x 1 into a 2 ohm load
Signal to Noise Ratio
> or = 100dB A-Weighted
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
(0-18dB) centered at 45Hz
Crossover (Front)
Variable 40Hz to 175Hz
12-18dB/Octave
HP Defeatable with 45X Frequency Multiplier
1.8k-7.9kHz
Crossover (Rear)
12-18dB/Octave
HP Defeatable
Crossover (Subwoofer)
18dB/Octave, LP
Dimensions
15" x 9" x 2" (38.1cm x 22.8cm x 5cm)
Next are Rockford Fosgate Silver 10" He2s. I don't have the rubber gasket. Never used it. I want $120 shipped OBO for these. They are RFP4210 and handle 400WRMS each. T/S sheet is at http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/fattach_get.php?p_sid=Fz1FO*Qh&p_tbl=9&p_id=155&p_created=1056749392
I decided to add the directed 5 channel I have too. It is the 1100D5.
At 4 ohms it's rated at 75X4 RMS and 275X1.
2 ohm ratings are 125X4 and 400X1(sub channel is 1ohm stable and rated to 600wrms).
Variable X-overs for channel 1-4 and variable low pass for Sub channel and Subsonic filter.
It has scratches and 2 mounting holes have been busted. I just used a washer to mount those 2 holes.
Won't win beauty pageants 5/10 overall on cosmetics.
It does however make a lot of power. This ran my D2 Brahma quite nicely and the main channels sound good.
This thing is like the a mix of the "Belle" and the "baby belle" It has he same power on the main channels as Belle but the sub channel has the output of baby belle.
All in all it is a great system amp.
I am looking for $275 shipped OBO for it.
I will make good deals for more than one item. Or take it all for $475 shipped.
Specifications
Damping Factor:
>200
Maximum Input
8 Vrms
Frequency Response
20Hz-20kHz ±0.25dB
Bass EQ
Crossover (Front)
12-18dB/Octave
1.8k-7.9kHz
Crossover (Rear)
12-18dB/Octave
HP Defeatable
18dB/Octave, LP
Dimensions
