5 1/4" Speakers CHEAP!!!!
jonnyv718
1. Product:
5 1/4 Sony Neo Speakers
2. Specs:
Stamped steel chassis with rear gasket for front mounting
Treated paper cone with rubber edge provides smooth, extended response
1" 4-layer copper voice coil on vented aluminum former
Neodymium magnet and extended pole piece
Magnetically shielded
Designed for compact sealed box designs
Great for line arrays!
*Power handling: 20 watts RMS/40 watts max
*VCdia: 1" *Le: 1.52 mH
*Impedance: 8 ohms
*Re: 7.71 ohms
*Frequency response: 80-6,000 Hz
*Fs: 81 Hz
*SPL: 85.3 dB 1W/1m
*Vas: 0.16 cu. ft.
*Qms: 7.81
*Qes: 1.10
*Qts: 0.96
*Xmax: 3 mm
*Dimensions: Outside Diameter: 6-7/16", 5-1/4" across flats, Cutout Diameter: 4-7/8", Depth: 2-1/2".
3. Description/Condition:
BNIB. After payment is received, they will be shipped flat rate priority mail. You should have them at your place in a day or two usually. I put a pair of these in my car, and they actually surprised me. I am using HU power with no crossover, and they sound surprisingly good.
4. Price: :
2 - $22 shipped
4 - $30 shipped
6 - $35 shipped
8 - $40 shipped
If you want more than 8, we can definately work out an even nicer price. Just let me know. Thanks guys.
5. Pictures:
Included in price
These speakers are perfect for replacements if:
1) Your speaker is fully blown.
2) Your speaker is worn from years of use.
3) Your car has 5 1/4" speaker openings.
Not so great if:
1) You have a powerful aftermarket deck.
2) Expecting a wide range of brilliant details. These are only 1-way speakers.
3) You don't like Sony.
Not so great if:
Why is everyone talking crap? I replaced a blown woofer from a JBL bookshelf speaker. Went ahead and ordered 2 from parts express Sony speakers for the garage. Was 32 shipped and Iam very happy! Free Bump //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks guys. I have logic behind my selling, and I am not trying to eff people over. They are good speakers regardless. Put 6 in each door and have a hayday... I am willing to do even BETTER prices if more than 8 are bought.
You guys know you cannot thread dump a f/s ad. You are lucky whitedragon took care of this thread before I found it, I would have done more than simply delete the offending posts.
I have a pair of Dayton 10s I would like to incorporate for my next front stage prob under my seats. I think it will be quite beneficial along...
28
373
203
It also lowers the amps efficiency and raises the current draw.
361
498
jonnyv718
jonnyv718
Elk Point, SD
Buckley2
    May 8, 2024
DEW123
    May 7, 2024
