Sold 4hp motor - 260shipped
no. the lms driver uses a modified 4hp motor. (extra slug, larger gap and such. they do, however, have the incorrect picture up. that driver pictured is a 4hp motor:) also- psy- 230 shipped? ok.. i will do it:)
IE- SOLD to me:)
... yea, if you'd ever hit me up it'd be better.
4hp > you
besides being a new 4hp motor......... what more do you need to know //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Here's your answer....
4hp motor = tc sounds 5200 motor.. some companies use it or a motor like it, a few are soundstream,RF,eclipse.
Which, wether you know it or not, is NOT the same as my Destroyer motors or my Rockford RFR-1812 motors or RD's SHW ...hince why I asked
btw...I hyperlinked the different subs above incase you didn't know what I was talking about again
Tripp
Tripp
You are correct. the destroyer is a janked up bstock concept csp motor. I don't know where he got soundstream from, but the 4hp WAS/IS used in the rockford fosgate team rf sub- here is some pics in case you don't know what i am talking about.. again. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
seriously.. get a clue.
I thought I read somewhere that the soundstream xxx used a modified 4hp type motor.. as I said, a motor like it, am I wrong or didn't you own a few for some reason chad?.. and also don't some team rf subs have a cactus sounds type motor? with a black topplate or the like..?
yes. the soundstream xxx is a different motor (bigger, wider gap) i liked the 4hp motors more:)
and yes- the black topplate team rf motors are cactus based. have a much smaller gap, and a few other small differences:)
Now what is the best way to remove my old motor and install the new one? I was gonna invert mount it into an old heavy enclosure I had while using a length of nylon tie down strap and a old golf club. Make a loop out of the strapping and place it around the assembly thn twist the club until tightens and twist. I was a mechanic and when I use to lose my filter wrench we use to do this, gives you a good grip. Now when you twist it I take it that it is righty-tight, lefty loosy, lOl. Also when reasembling would a little drop of blue loc-tite be recommended? Polo..
I am familiar with the trfs...but the ad said a "new 4hp motor" ...so are only the trfs motors called 4hp? I was under the impression that 4hp ment a motor that took a 4" coil
JL Audio
ThugStep
JL Audio
KY
Safe_Cracker
