4ch amp switch, since then popping and weird RCA noise?!?
  • 2
SQBubble
MTL
Everything was working great until i switched my 4ch amplifier and completly forgot to disconnect the power line from the battery and i think i messed up something...not sure the cause though... now both my 4ch amplifiers make really weird noise and the really weird part is that my sub mute option on my kenwood x997 H.U. doesnt work anymore only WHEN RCAs ARE CONNECTED TO THE 4CH AMP... my REAR channel's xover gets applied to the SUBWOOFER amp instead of the REAR channel... so i disconnected the amp. and my sub amp pops when i turn off the car.... disconnecting the rca from the subwoofer amplifier made the pop go away ..the next day i tried the 4ch amplifier and it actually worked great as long as i dont turn on the engine or even go on contact ignition, if i do go on contact ignition it makes a really weird sound and its even worse when i turn on the engine, but all of these noise goes away when the RCA's are unplugged... im running my factory rear speakers off the head unit's amplifier right now and its working fine, no noise, no issues... does that mean its an isolated issue with the head-unit's RCA's preout that are messed up for sure? or could it be something else.. im really curious to understand how could this happen though ?..did i blew/shorted the RCAs or something in the headunit??
I would suspect the head unit.  Do you think you could have had an accidental contact between the RCA's and the energized power wire?  Even contact between the power wire and amp chassis can damage the HU since the HU shield is tied to the amp chassis through the RCA's.
You can try running a ground between the HU chassis and the amp chassis or the classic Pioneer RCA ground fix to verify if you did damage the RCA shield connection inside the HU.
thx for the explanation! yes actually i was tired when i did the swap and its very possible that had rcas plugged in before i plug in the power and ground, or even some strands were loose and made contact to the amp's chassis... never working on these things when im tired again thats for sure!
i did isolate the issue and it must be the head unit indeed, i connected a home dac/preamp to the amplifiers and everything is fine, no noise , no issues. so definitly coming for the pre-out
Im glad the amplifiers are in good states though.
a new head unit is on its way
55
86
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
234
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
282
It also lowers the amps efficiency and raises the current draw.
232
SQBubble
SQBubble
MTL
SQBubble
    Apr 28, 2024
    Apr 28, 2024
