4AWG power cable.... FUSE?????
deserte4gle
Hi guys,
Currently im running 2 units amps..... im using 4AWG power cable with 1 unit 100A fuse and 1 unit 60A fuse...... what's the minimum and maximum fuse i need to use?? or any recommended fuse that suitable with my setup??
thanks guys.. really appreciate your help...
thanks
i read somewhere if the fuse at the batt is bigger than the rate it should be, it will loss in power...
so, just now i re do the wiring again.... for my amp mid(soundstream) i used 4AWG with 100A fuse... and for the woofer amp which is bazoka(NO brand) i used 40A fuse with 8AWG..... both of it independent....
i dont have budget to buy distributor block as im out of budget now days.....
so is it ok with my wiring???
a 4 ga with a 100A fuse/amp and an 8 ga with 40A fuse/amp should work fine.
owh ok... thanks dude..
between, inside the amp got switch written there High current and High power.....
which one should i choose for sound quality????
here's the spec of my amp...
High Power:
2 x 25W @ 4 ohms
2 x 20W @ 2 ohms
2 x 100W @ 1 ohm
1 x 50W @ 8 ohms bridged
1 x 100W @ 4 ohms bridged
1 x 200W @ 2 ohms bridged
High Current:
2 x 12.55W @ 4 ohms
2 x 25W @ 2 ohms
2 x 50W @ 1 ohm
2 x 100W @ ½ ohm
1 x 25W @ 8 ohms bridged
1 x 50W @ 4 ohms bridged
1 x 100W @ 2 ohms bridged
1 x 200W @ 1 ohms bridged
Fuse: 20A
deserte4gle
deserte4gle
MALAYSIA
deserte4gle
