I'll be hooking up 2 JL amps, ones a 300/4v2 and the other a 500/1v2. One requires a 40 amp fuse and the other a 50. I'll be putting in a 100 amp breaker at the battery. I already have 4awg pulled thru the fire wall to the back wall of the truck, then split into two 8 awg at a fused dist. block going into 2 Alpine F series amps (being replaced by the JL's). I was wondering if I can have the 4awg main line like it is now, but upgrade to two 4awg's going to the new JL's from the fused dist. block, instead of the 8awg's ? The JL's recommend 4awg inputs, I'm sure 8 is gonna be fine, but I have a lot of 4 left over to make it work.
Any harm doing that or is it always best to run smaller wire after you split it up like that?
Thanks in advance
Thanks in advance
