Sold 4000w Tru Technology Sledgehammer
Renegadesrun
Doesnt play well w others
Class A/B goodness. 800 plus some 0 to 4 ga connectors thrown in.
- Very High Voltage/High Current Class AB Mono Block Bass Amplifiers
- Absolute Sound Quality Performance with Tremendous Controlled SPL Output
- C & C Machined Heatsink with Hand Grinded Heatsink Fin Edges
- Constant Rated RMS Power Output until Thermal Shutdown
- High Voltage / Current Unregulated Bi-Polar Power Supply
- +/- 90 Volt Rail Voltage
- 20 ON® TO-3 (250 Volt) Metal Case Output Devices
- 24 I.R.® HEXFET® (60 Amp Rated) Power Inverters for Efficiency
- 4 Hand Wound Power Transformers
- 8 High Speed Rectifier Diodes
- 4 100Volt 6800mf Capacitors
- 2 Pairs Complimentary Transistors for Input Stage
- 4 3 inch Variable speed Intake/Exhaust Fans
- 69.1% Efficiency @ 4 W (Full Power)
- WIMA® Polyproplyne & Mylar Capacitors
- Balanced Line input capability
- Symmetrically mounted heat generating parts
- PROPRIETARY RF Grounding Techniques used for
Improved Reliability and HF noise rejection
- Power section uses Discrete Circuitry throughout Audio Path
- Linkable Amplifiers (H-1)
- 18dB Low Pass X-over (40Hz ~ 300Hz)
- 24dB Subsonic filter (10Hz ~ 100Hz)
- Remote Bass control knob (Optional)
- 4 Gauge Power/Ground Input (2 Sets for SH-1)
- 8 Gauge Speaker Wire Output
- Hand Built in California, U.S.A.
Price: MSRP $3500
SPECIFICATIONS:
Model: SH-1*
Channels: 1 CH
Frequency Response: 10Hz ~ 300KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.:
4 Ohm RMS: 2,000W x 1
2 Ohm RMS: 3,000W x 1
1 Ohm RMS: 4,000W x 1
(Burps @ about 6000w for you DB Drag junkies)
S/N Ratio: > 100dB
Input Sensitivity: 0.16mV ~ 4 Volts
Damping Factor: > 700
Efficiency: 69.10%
Fuse Requirement: 120 x2 Amp
Power Supply: 11 ~ 17.9 Volts DC
Low Pass @ 18dB / oct: 40Hz ~ 300Hz
Sub-Sonic @ 24dB: 10Hz ~ 100Hz
Remote Bass Knob: Yes
Bass Boost: No
Dimensions: (L x W x H): 15" x 8 13/16" x 6 3/4"
Weight: 25 lbs. / 11.3 Kg
More pics. http://ampguts.realmofexcursion.com/TRU_SH-1_Sledge_Hammer/
Shipping will be a flat 50 dollars anywhere US. Tracked, delivery confirmed, heavily protected, and insured. (after handling is done i will refund the diff)
ebay ad http://cgi.ebay.com/4000w-Tru-Technology-SH-1-Sledgehammer-Class-A-B-No-Res_W0QQitemZ190315370845QQcmdZViewItemQQptZCar_Amplifiers?hash=item2c4fae195d&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1234|240%3A1318|301%3A1|293%3A1|294%3A50
kman...Yea right. Born during the day..... but not yesterday.
4 refs in buyer/seller feedback in here alone + lord knows how many other forums including my own.
This girl isnt leaving my house without cash.
audioatg..... you just read what you want? Its FS 800 cash regardless of auction.
Renegadesrun
Renegadesrun
Indiana
Renegadesrun
