40.1
stevew007
sold
mono channel IA 40.1 amp is in great shape just got it back from dbr with new fets and new driver also has the upgraded soldering done to it.also had to retap 2 of the speaker terminals
sold
Dam thing that makes power. i cant imagine it at .5 ohm //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
GLWS, if only i had the electrical to power that beast..
What kind of electrical would you need to power it at .5 Ohm? Also how many watts could you expect at .5 ohms?
Thanks,
I powered 2 @.5ohms each off of 2 125lb batts and a 200amp alt.BUT i dont drive around full volume like some kids i know.
keep in mind as long as you dont mount it to the box these amps have a great protection circuit. the 2 i had before I couldent tell you how many times i protected them and they always came back on.
i never clamped these amps before but seen plenty of people say 6k-7k on 17.5 volts and 4000-4700 on 12 volts and this is for 1 amp
I powered 2 @.5ohms each off of 2 125lb batts and a 200amp alt.BUT i dont drive around full volume like some kids i know.keep in mind as long as you dont mount it to the box these amps have a great protection circuit. the 2 i had before I couldent tell you how many times i protected them and they always came back on.
What voltage were you seeing on the 2 batts and 200 amp alt? Also does it have double inputs (Power and Ground)?
Thanks,
Thanks,
in my astro playing beastie boys intergalactic it never went below 12.6 volt's and that was full throttle
yes double power/grounds
stevew007
stevew007
west sacramento
stevew007
