Sold 4 Sundown Nightshade 12" D1 custom / 1 15" D2 NS
RetroAudioinc
Custom Car Audio Decals
1. Product:
2. Specs:
Info from Jacob:
They have 3 prototype spiders (little lower Fs than the current models, these are slightly softer), plus double leads, new aluminum pole plugs, and the newest D1 coil with collar vents.
I asked if it would still be ok on 2000wrms and got this:
While this spider is softer at rest it has a progressively increasing stiffness -- so should be fine.
Specs from site should be close:
  • Dual 2-ohm or Dual 1-ohm Voice Coils Available
  • 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
  • High Temperature Aluminum Voice Coil Former
  • 1500-Watts RMS Power Handling
  • Over 2 inches peak to peak excursion
  • Wide, triple-layer foam surrounds for high excursion
  • Extremely strong paper cones w/ stiffening disc
  • Thick poly dust caps
  • Cast Aluminum 12-spoke basket with cooling vents
  • Triple Stacked 1" x 9" magnet slugs for high motor strength
  • MSRP - $629 USD
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
3. Description/Condition:
This one was only used by jacob him self I have not used this one still in the org box from jacob. I am using the other 2 in my truck and just did a show with them and they are both on my memphis 4k and sounded great did a 148.7 with them.
4. Price: :
$375 shipped.
5. Pictures:
A few of jacobs photos nothing has changed
1. Product:
Sundown Nightshade 15" D2
2. Specs:
If you want a loud subwoofer to use both daily and in the SPL lanes then look no further than the Sundown Audio Nightshade. Many Sundown Audio customers are already using Nightshade woofers to achieve SPL levels in excess of 150 dB on music in their vehicles! *
The Nightshades feature strong paper composite cones with an additional stiffening disc located behind the thick poly dust caps. The tinsel leads are tied down to the spiders so you never have to worry about the leads slapping or popping against the cone and spider at high excursion levels!
The Nightshade woofers are assembled in the USA with only the best high strength adhesives and materials.
* Please use caution as excessive SPL levels such as those achievable with the Nightshade subwoofer can cause permanent hearing damage!
  • MSRP - $629 USD
T/S D2 **:
RMS: 1500
Z: 4 ?
Re: 2.92 ?
Fs: 41 Hz
Qms: 9.36
Qes: 0.46
Qts: 0.44
VAS: 11.7 L
BL: 22.8 NA
Used, I got it on this site from allout13. never had an issue with it, was in 3.5 cube box built by spy, sounds great off my 3000D it will take 3000wrms all day I never had a single issue only did one comp with it.
4. Price: :
$375 shipped
5. Pictures:
sorry but this is from your other thread same subs right?
Subs:
(1) Pioneer TS-W3001D4 BNIB $115 shipped. Good sq subs..
(1) Pioneer TS-W2501D2 BNIB $110 shipped. Good sq subs..
(1) Pioneer TS-W3001D2 BNIB $115 shipped. Good sq subs..
(1) RD HW v.1 SQL Version 12" D2 $290 shipped. super heavy sub, will take 3k all day and sounds really good.
(2) 12" mass destruction napalm's D4's $200 shipped each Killer subs at least 40lbs each.
(1) 12" OZ Audio 300L D4 $150 shipped I do have a spec sheet for this now, that tells you box size sealed or ported and what to tune to.
(1) Sundown Nightshade 15" D2 $375 shipped
(4) Sundown Nightshade 12" D1 custom $350 shipped firm.
(1) Boston Acoustics SPG555 D2 $400 shipped SOLD
Subs:
Yep and $350 x 4 is $1400..
Point?
RetroAudioinc
RetroAudioinc
Indianapolis, IN
RetroAudioinc
