4 subs wiring help??
yes i already have them. i couldnt really find dual 4 ohms available on those they r lanzar opti1232d
if i unstrap em they would run at .5 ohm each :/
how can i wire 4 dual 2 ohm subs to 2 planet audio big bang strapped @2 ohm stable. help me please1!!!!
If you think you could squeeze 1.6 and still be stable, here's the way to do it:
Wire 2 subs each to 4ohm (series) then wire those two together to 8ohm (series)
Wire the other 2 to 4ohm (series) each.
Then parallel the 8ohm total pair to the two 4 ohm subs
= 1.6ohm
8ohm + 4ohm + 4ohm = 1.6ohm
will try. are u sure the subs wont go out of phase??
Not unless you wire something wrong. (I assume you know what is meant by series/parallel)
Phase errors happen when one sub or more is moving opposite of the other(s) causing cancellation of the sound waves.
= 1.6ohm
You're kidding right? You realize that the ones that are wired together to 8ohms would get like a 4th of the power the other two get, yes?
You can wire each pair to either 2 or .5 ohms.
You can wire all four to either 4 or 1 ohms.
chsvick5
chsvick5
Laredo, TX
05trailblazer
BP1Fanatic
BP1Fanatic
