4"T speakers?
Are there any good inexpensive 4"T speakers (full range) out there? I have a '95 4runner, which uses 4"T up front ... I could use a standard 4" but I don't want to cut/chop/file if I don't have to.
All I could find is the Rockford Fosgate FRC3204T at crutchfield. It seems nice enough and not too expensive, but I'd like to see some alternatives if I can.
While I'm at it, do you know of decent full range 6 1/2"s for the back that would match well? I'll probably order from crutchfield since they make everything so easy, but if there's a better place (with better deals) point me that way...
If it makes a difference, it only has the factory cassette headunit in there and an add on kenwood changer... I'll probably upgrade to a CD/MP3 headunit like the RF RFX9300 soon, but nothing beyond that; no seperate subs amps etc.
Thanks all
-ohio
I can recommend jbl gto 6.5's. I have those in my 91 tercel and they are loud!!! As for the front speakers, they may be made by fujitsu ten? If so, then you don't have to upgrade because they are eclipse! That's what's in my tercel and I haven't had to switch them. So take out the speakers and see if they are. As for a head unit I'd recommend a pioneer. I have the model deh-p6300 and it's awesome. It has cross-overs for both speakers and subs as well as a sub control. It's the best deck for my money. If you do decide on getting a pioneer look at the 6400, 7400 or the 8400. I would avoid the 7400 as it is practically the same as the 6400 but it plays mp3s. The 8400 would be a better deal if you wanted to go a bit higher.
I can get the jbl gtos for you and have it shipped down to you if you like. They won't be expensive at all.
I hope this helps.
Nick
ohio
ohio
corporate hell, 4th floor
toyotanut
