4-ohm stereo VS. 4-ohm bridged
noob with an RS
i poop on you
i notice in the following description of this PPI amp (and other amps) that 4-ohm BRIDGED seems to put out more power than 2-ohm STEREO.. what i'm wondering is if there's a possible way to wire the amp in 2-ohms BRIDGED??? and if so, i assume this would give maybe almost twice as much power as 4-ohms BRIDGED??
Detailed Description of the PCX2400:
PCX2400
Precision Power PCX-2400 2-Channel Amplifier
Stereo, 4 Ohms: 2 x 400 Watts
Stereo, 2 Ohms: 2 x 800 Watts
Bridged, 4 Ohms: 1 x 1600 Watts
BRIDGED, 2 Ohms: 2 x 3200 Watts
RF Power lines, Zapco C2k's bare a few that i can think of....
Soundstream Rubicon //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But no, as 3.5max said, you can not wire that amp to 2ohm bridged. It would either 1) Kick into protection, or 2) cause damage to the amplifier.
sometimes amps SAY they are 4ohm stable only when bridged.. but they can be modded to drop to lower impedances.
i doubt you will get a PPI to do that however. i just doubt its going to happen. all PPI amps i know of (back then) were ONLY 4ohm stable when bridged. do NOT try it at 2ohm or it WILL break.
Don't forget the References too //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
noob with an RS
i poop on you
noob with an RS
earth
SMOKEY
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
