jdubbau
Ok I am on a very very tight timeframe here and really need the design and cutsheet like yesterday. I will pay a little more for a quicker design if needed.
Really need the design FIRST thing tomorrow morning or by Noon if possible to get rolling.
I was looking to do something like or similar to downfiring subs port to side with amp mounted below subs so that everything is hidden. Cannot do rear seat with box built under as he is going to take the seat out every once and a while. Any other ideas are welcome.
I hoped to have a very accurate response for him with some ability to get loud but really sound great.
Max Dimensions, T/S, and Recommended box sizes from ED.
36" Wide X 18" Tall X 8" Deep.
Spec e3.6 Subwoofer
Sealed Enclosure Yes
Vented Enclosure Yes
Infinite Baffle Yes
Car Audio Box Size Suggestions Outline
Spec e3.6 Subwoofer
Sealed ( small ) 0.2ft³
Sealed ( ideal ) 0.25ft³
Sealed ( large ) 0.3ft³
Vented ( ideal ) 0.5ft³ Tuned to 30Hz
Vented ( DDLoud) 0.5ft³ Tuned to 35Hz
Qts: .29
Qes: .30
Qms: 10.5
Fs: 28.00Hz
Re: 3.2
Vas: 22L
Mms: 50.0g
Bl: 13.30T*m
SPL: 85dB
Sd: 114cm²
Xmax: 13.0mm
Voice Coil: 38.0mm
Magnet Width: 5.000"
Cutout Diameter: 5.700"
Mounting Depth: 3.518"
Weight: 7lb
Total Height: 4.000"
Displacement: .04 ft³
Outside Diameter: 6.75"
Spec e3.6 Subwoofer
Infinite Baffle Yes
Spec e3.6 Subwoofer
Qts: .29
Qes: .30
Qms: 10.5
Fs: 28.00Hz
Re: 3.2
Vas: 22L
Mms: 50.0g
Bl: 13.30T*m
SPL: 85dB
Sd: 114cm²
Xmax: 13.0mm
Voice Coil: 38.0mm
Weight: 7lb
