I will be wiring a 4 channel amp to my two front speakers and bridge the other two channels to the sub. It will be a stock stereo and the amp has speaker level inputs. Is it possible to use this 4 channel amp to power the front speakers and the sub while leaving the rear speakers working normally through the stock stereo? I plan on tapping into the rear speakers for the sub, which will then mute my rear speakers and the signal will go through the sub. But is there any way to keep the rear speakers running and maybe use a y splice on the front speaker inputs so that i use the same signal for the front speakers and the subwoofer without having to touch the rear speaker wires? Or any other way? I was thinking the y splice might mess with the signal but i'm not 100% sure. Any thoughts would be helpful. Thanks.
