Looking to power her front stage, polk db651, and a Shiva X2 1.5 cubes sealed. So far the amp in the lead is a Soundstream TRX 4.640 for $99 shipped. Anyone have a better deal for me?
You expect that amp to power your comps and sub?? Not a chance in hell. Ur looking at 100x2@4ohm to power the comps and that leaves you with a 320if you bridge the last 2 channels. 320watts is not near enough for the shiva. Thats assuming the amp even does rated plus its a a/b so it will **** hella juice.
If so they recommend 500-1500watts in a 1.5cf sealed box. I would give it no less then 1000watts any less and I feel you will be disappointed.
For under $100 I know of no single amp that can do what your asking for.
P.S I love the shiva's you made a great choice. If I could fit 2 12's in a proper ported box in my trunk I would be sporting these. Truly beastly low end monsters.
I'm just getting into car audio, coming from home audio. I have been running the shiva on 500watts for a year now with no problems, but I emailed Kevin Haskins just to ask his opinion on power before putting it in the car and the last thing he said was "Most of the time failure mode is mechanical (it is beat to death) rather than thermal so any amp from 300W-1000W will work well."
That being said, what would you recommend to run these speakers on a budget and keeping it under 1000watts total?
The website for them states clearly 500-1500 is recommended for a 1.5cf sealed box. Id do my best to feed it the full 1500 but no less then 1000 anything less then that then I would get a different sub.
I never really cared for AP but they are cheap and will do rated so you cant complain. Looking at $200 to your door not gonna find much cheaper that will do rated. Unless you buy used and even then you will have a hard time finding anything else used under $200. Got to pay to play.
What ohm load is your sub, should have asked that before I made a recommendation.
