4 8" W7's
What kind of amplifier are you running?
4 single 3 ohm subs can be wired to these ohm loads:
12
0.75
None, yet. I haven't purchased them but was planning on doing it today or tomorrow. Do you have any suggestions on amps?
The box i'm looking at right now is this (link). I would rather have a ported box though.
What kind of electrical do you have (any upgrades)?
As for the enclosure, I would think ported would be a better option, but you may have to lift your seat some to make it work fully.
Where in TX are you located?
I'm in the Woodlands area, and electrical, I have 2 optoma yellow top batteries and looking into getting a ho alternator
Down by Huston, nice to place to live/visit.
The yellow tops are not as good as they used to be, but for your application they may do just fine.
If you get an alt, then you will likely be fine with an amplifier that is ok at 0.5 ohm and just wire your subs to .75.
Maybe get a solid 2k rms @ 1 ohm and set it correctly and you should be fine.
Do you know any amps that meets that?
Either of the two mentioned are good amps. I have the aq/ sq 2200d and I love it. Remember you can always turn it down.
Edit, I thought you meant to power 4-8's or 1- 12. I wouldn't run both either go one way or the other.
xXxKUMQUATxXx
xXxKUMQUATxXx
Texas
CrossoverOre
