4.5cf @ 40hz, kerfed! Worklog with lots of pics!
Use some body filler and smooth that lip on the double baffle out... make it 100% smooth...
nG
x2. I knew you were gona mess up the port like that.
grind down the front baffle so its smoothed with the port bend.
Actually, I really like how the kerfed port is inset. I just think it looks nice. I doubt having a lip that far out affects the sound. I'm gonna leave it.
nice dude , hows the 40hz sound ?? are you able to listen to it daily or is the tuning a little too harsh ?? the xxx is juts a better sounding sub though cant really compare them.... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sounds pretty much like ***, but I expected it. I just wanted something that was loud for comps.
Comparing theXXX and HD3 is comparing apples and oranges because they are built with different objectives in mind. The XXX sounds great and gets loud, and the HD3 sounds like *** but gets ridiculously loud.
so dont you think its tuned a little higher with the 9" spot in the port?
Hell if I know.
its that bad //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif ive heard at 40hz they sound ok but get very loud.....maybei should lower my tuning a bit....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Meh, after listening some more, it's not that bad, really... I played late night tip and it did alright.
What's the comparison between the low end on the HD3 and the XXX? High end?
The XXX kills it in the 40hz and under region, but in the mid 40's, the HD3 is loud as hell. In the upper notes, the XXX is almost nonexistant, as is common for XBL^2 subs.
nice work jman. Lets hope it holds up better than that XXX box //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
My hd3 15" didnt sound terrible.. that was probably due to the fact it was tuned to 34 though.
Again, nice work.. curvey ports ftw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
Pyro_By_Nature
