4 18s walled in 94 astro
it doesnt sag any more now than it did:laugh:
but thats cuz the springs are allready flattened out. so i am gonna put in one or two more each..
i would like to airbags but not yet. too much money...
and i will be throwing 5 more batteries in when the 9 get the second amp.
they will break over time from being old now when you have 3000lbs in it and the springs are in a negative arch one little pot hole,curb or anything will snap them and with that much weight it is not drivable to me.you need to upgrade brakes to some bigger ones maybe upgrade the master cyl. thats alot of weight to stop when your doing 55mph and have to stop in a hurry
I see, mine it is on this negative arc but it is towed, probably will break anyway.
so i cant add a leaf spring because they are fiberglass.
whats gonna be the easiest solution..
i seen what tommyk suggested. what else?
Not much else you can do really. Getting rid of the fiberglass leaf springs is the FIRST thing you should do.
If that doesn't quite do it, then helper bags or add-a-leafs would be the next step.
how is that i have 7 batts for one amp thats only 10 batterys in a van thats walled of i have seen 40 50 plus in a van before
each of my batteries weigh 110lbs each, and the box weighs a good 600lbs maybe more? then theres a sheet of 1 in mdf on the bottom of the batts and the top
so:
1100 lbs in batts
600 lbs in box + subs
100 lbs in cable
say another 200lbs of misc crap and amps and speakers and deadner and such
and you (500lbs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif)
That van should be riding on it's frame by now, if not it will be soon
so:1100 lbs in batts
100 lbs in cable
//content.invisioncic.com/y282845/emoticons/swordfight.gif.e3de6069f3ffe402fc3ab4a827365101.gif
//content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
DB-Audio
