4 18s walled in 94 astro
Hey
You don't need to run them at 0.5 ohm, we only recommend that for burps on street classes of dB drag (limited battery)
plan on running em daily at 2 ohms and .5 for competiton only to achieve the highest number possible.
but i will still wanta beat everyone next year on music.
Mine did... but I had a 557 big block ford and a C6 in the back as well as pulling a '73 Mach 1 so.... made it about 120 miles then hit a pretty nasty hole about 5 miles from home and obviously stuff broke //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Haha nice, the amps are in your way, don't worry.
Question for the astro tech guys, the fiberglass springs will break with too much weight?
they will break over time from being old now when you have 3000lbs in it and the springs are in a negative arch one little pot hole,curb or anything will snap them and with that much weight it is not drivable to me.you need to upgrade brakes to some bigger ones maybe upgrade the master cyl. thats alot of weight to stop when your doing 55mph and have to stop in a hurry
Sure can. Eric Alexander broke one on his van.
Need to swap them out for the steel leaf springs on newer model astros. Also, some helper bags and heavy duty shocks wouldn't hurt either. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
DB-Audio
