4- 18" in s10 blazer ? non wall.
Should be enough if you give each sub 6.5 cubes. That's 26 cubes net, and you could get away with 25 cubes net because you're running a lot of subs. The more subs that share a common airspace, the less airspace each sub requires. Usually about 10-15% less iirc
Bracing, walls, and sub displacement shouldn't be 15 cubes
big scott
blazin low, and loud
big scott
edgewood, md
tprj82
