4 15s in a wall
i gonna convert my wall over to 4 15 l5s just because i dont quite have the electrical to do anything real serious yet. and theyre not too expensive refurbished so im just going with them
Im tryin to break 150, And do a hairtrick cause ive had big systems an never done it before. i have a lil bit of money to spend(2500 Maybe More If I Have To) but its a monte its smaller then a impala an way bigger then a cav.
Woofer Size 15"
Fs 37Hz
Revc (ohms ) 2.00
Vas 65 Ltr
Xmax (mm) 19
BL 24
Qms 3.19
Qes 0.45
Qts 0.39
Sensitivity 1W/1m 92 dB
Magnet Diameter 9.0"
Coil Diameter 3.0"
Useable Throw 3.0"
Continuous Power 2000 W
Music Peak Power 5000 W
Mounting Depth 9"
Circle Cutout 14"
Overall Diameter 15.5"
Bolt Hole Circle 14.75"
Motor Depth 4.5"
Basket Depth 4.5"
Displacement 0.21 cu. ft.
Weight 62lbs
I love these subs. Even in a 9cube box it sounds great. And loud as **** too.
Prices are pretty good. You should check with TeamSouthrnBass (link in my sig) He is selling a lot of them with a $50 discount.
If you got 2500 for amps n subs n stuff to install....look into audiopipe do 2 3000.1 and 4 of the eyecandy 15's do 2 off 1 1500.w and its killin the civic and its a trunk box....or 4 ez street audio subs.... b a few weeks b for the 15's are in...is this a street setup or comp?
4 omegas at 420 shipped, and 2 RD 3250 v.2s for 425 each. for 2530. sorry its a bit over your limit.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
z34choppin
z34choppin
East Tawas
z34choppin
