4 15's in a Beretta???
Decipha
www.EFI Dyno Tuning.com
Does any one here have a beretta or corsica?? I was thinking about fiberglassing the ENTIRE TRUNK (spare tire compartment and all) to make a box for 4 15's but before i attempt it and waste lots of $ i want to make sure its possible?? Anyone have a beretta or corsica or some experience with these trunks?
hmm i think 4 15's will just about fit in that lil trunk. I had 1 15 solobaric and the box was barely making it in there it was too tall to stand so i had to have the sub facing up towards rear shelf . Again if you do decide to use the entire trunk i think you could manage to sueeze 4 of em in another thing to consider is the type of enclosure u plan on using
You build a wall inside the cab effectivly taking your back seat away //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I think after what i've read in that type of car you would probably get better output if you walled off 2 15's
What about a false trunk floor? the bottom of the enclosure would follow the contures of the trunk floor and the top would be a the flat mounting surface for the subs, the trunk would be usless but you would avoid having to ditch the rear seats in favor of a wall.
Somthing like this-
Somthing like this-
even doing that i don't know if the beretta has enough room...
Yeah I also think youd have to have a wall or cut the rear deck right out and take your seats out, have to 15's facing where the rear deck was and 2 15's where the back seat was.
Decipha
Decipha
New Orleans, LA
andy1234
