Alternate to fiberglass matte?
I dont think so. By the time you waste so much resin trying to soak it in, AND all the itchy fibers all over your body, its not worth it. Normal fiberglass wont work because matting or cloth used specific for fiberglassing has a special binder used to allow the resin to break it down when applying it. This kind of fiberglass you have is probably also treated to keep from breaking down in your house (which is its normal function). The resin may not react well with this coating it has. Matting is so **** cheap, and its easy enought to run to a Lowes or Homie Depot and pick up a few packages of it, its not worth it to try.
Or from another thread I read earlier, you may want to try and use paper towels (thats a joke, I know, but some tard actually thought it may work)
oh, and as we decided in the other thread........ paper towels won't work either.
Are you sure cause the resin is already very hard, almost like the matting isnt needed. What about adding just more layers of resin? Will that do the trick? //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
dude. just try it. stop asking - and do it.
you tell us if it will work, because obviously you dont wanna spend the money, i dont wanna get into it, and hell- how should we know. im sure as hell none of us has ever done it.
if you do try it. make sure you peel it apart so the layers are thinner.
Raven
Lacking social skills!
Raven
Michigan
BeanII
