4 12's which way to face theM???
JCivicHb
im getting four 12s, but i can only fit them im two are facing up and two are towards either the front or back, or 2 front and two back, or two front and two on sides etc.....its a rectangle box in a civic hatch, which way should i face them all??
You Think 2 Ported Would Be Louder Than 4 Sealed? They Are Comp Vrs By The Way Powered By A Jbl 1200. Havent Bought Yet Tho....
Btw 4 Cubes Total, So Like 1 Per Sub.
more than likely, yes. With only 2 subs, you will be feeding each sub to its full potential, and you will have more airspace. P
But then again, 4 subs just look so badassed. I dont think you need to be worried about cancellation too much.
Well The Jbl Does The Good Power At 2, 1 Or Lower So Is There Any Configs I Could Use With 4 Or 2 Ohm Subs To Get 3 Subs Down To That Load??
well actually if you had dual 2 ohm subs, you could wire them in series, and then in parallel to the amp, giving you a 1.33 ohm load... and since it does full power at either 1 or 2 ohms, it would be fine.
JCivicHb
JCivicHb
Denver
SSS 18734
