4 12 SDCs or 2 15 HDCs (daily)
Which one? off same amount of power (~5000w)
  • Total voters
    17
ARSkemp
FI-AQ-PA-AB-Profile-MB-RD
I'm going to have ~ 9ft^3 after port/sub displacement tuned to ~38hz.
I'm wondering what would be the better option, I will be using an AB500.1 @ .5ohm
Im estimating getting ~ 5000w @ .5 ohm, so which would be the better choice?
There's more cone area w/ the 12's, but from what i've seen on this forum, i don't think they'd like 1250w a piece, so the gain would be turned down a little bit. However, i am assuming since they are less power hungry they should be less efficient as well?
From what i gather, the 2 15" HDC's should be pretty happy on 2500w each, so no problems there.
Dual 4's should work, shouldnt they? Each sub wires to 2ohm, Then 2 would then wire to 1 ohm, and then .5ohm when the pairs are wired together. or am i not thinking this right?
So far the poll is split 5/5
You guys aren't making my decision any easier to make!!!
So far i'm leaning toward the HDC3 15's, mainly because more people have run the power i want to run on them successfully, and they are cheaper.
Almost a hundred people have viewed this thread, and only 10 posts, 10 votes? Please, i need more input!!!
ARSkemp
ARSkemp
Salas/Chico, CA
wu501
vegang
vegang
