4 12" l7's
king ranch
Banned
i kno you guys are tired of answering questions for me but i was wondering what will be louder 4 l7's sealed or 2 l7's ported
box dimensions will be 26x17.5x30
mount 2 on top and one on each side if there is enough air for four
min is .88cu ft max is 2.0cu ft recommend
what do you guys think also for a little while if i do four they will only get about 400rms a piece then later down the road will get there 750rms
you may get a lot of cancellation by putting subs on diff sides so wouldnt go that route.
If you put all the subs on the same side sealed that may be louder due to cone area
Atleast thats my .02
ok what bout in bottom of box and ontop of box the most space i can use is the dimensions i gave
so idk if i should go 2 ported or 4 sealed either way all four or the 2 wil be hooked up to a 1500.1 kicker amp
ok what bout in bottom of box and ontop of box the most space i can use is the dimensions i gave so idk if i should go 2 ported or 4 sealed either way all four or the 2 wil be hooked up to a 1500.1 kicker amp
Im thinking the 2 ported with only a 1500.1 to them.
I just dont think 1 1500.1 would be enough to power 4 L7s
ok thanks and with the dimensions it will be about 6.6 before sub and port displacement so i should have 5cuft or more total correct
and tuned 32-33hz should be decent right
whats the dbs gonna be around with that setup
king ranch
Banned
king ranch
fl
PSturmer
