4 12'' or 1 18'' which will be louder
should u say that about 2 15s running daily to? or no? i was thinkin 2 15s or a single 18..got like 3k watts..
the 15's will have more cone area than a single 18. I just perfer single sub setups. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My vote is for 4 15" Type R's on the 3000D @ .5 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
That's just me though
Four 12's vs one 18 - I'd go with the 18 just for simplicity sakes, and it will still get plenty loud believe me.
Okay guys, i was either going to go with my budget build, since i already have 2, 12'' Type R's and just buy two more since these are so cheap. But i seen a video of a guy with a 18'' moving an aluminum roof so i was wondering which would be louder??? i have a sundown saz 3000d so power is not an issue, but 3k to one 18 or i drop it down to .5 ohm and push 4 12'' and give them 1k apiece,...what do you think!?
HAHA, I take it you watched my 18" Fi BTL "Building Flex" video //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
When I made that vid I only had 2000rms on it. I upgraded my Alt with a 260amp irragi and did another run of 1/0 gauge then installed a couple Optima G31 battery's to feed a Rockford T30001.bd that was giving the BTL around the same power that you have. You should of seen how much louder that aluminum roof was vibrating when I went back to the same spot I made the original video. It actually hurt to be in the car.
My box was 37" wide x 27" Deep x 19" Tall, about 6.7 or so cuft.
The "L" port was 5.75" wide x 17.5" tall giving me 100sq.in. of port.
The port went back 21" and the 2nd piece of the "L" port was 6 long".
This tuned the box to about 32hz.
I did a double baffel with thick support dowls going from top to bottom, with this setup it will get VERY LOUD...
Next time, run your bracing rods the other directions. Since you had a vertical slot port, AND double baffles, the axis that you braced (top to bottom panels) was actually already your strongest axis. The braces should be run to the front/back panels, and side/side panels.
Nice blazer btw.
there is more involved than just cone area:fyi:
Assuming we are comparing apples to apples, the four 12's setup would pretty much have all the advantages. more cone area (already discussed), more motors to soak up wattage AND minimize power compression (and increase longevity). More displacement potential AND the ability to use more wattage... can only equal more output potential... sealed OR ported.
Joseph M
149.00 db club.
Joseph M
Moxee, Wa
Joseph M
