3X 10 or 12"
js1
I'm now starting to lean toward the XXX because I know I won't be disapointed with it. Money is an issue...
What sub would you get for an Expedition running a 1500d brutus amp and the other stuff in my sig? They both have the same basic specs but I can run a smaller box with the 10" and it will hit. The 12" is only like $10 more and will probably get louder. Any reasons to look at the brahmas and how much are they?
It will most like go into some sort of ported box behind the rear pass bench.
I'm ordering something in the next week or so and it will probably be the 10" unless the RE8's or something else changes my mind. Feel free to confuse me some more with other valid options.
-js1
Brahmas ey?? I am currently running 2 of them. The one word i noticed from your post was "Louder". Bumpin bass is your priority. Am i correct??
Stick with the XXX
SQL for a DD. I listen to old Rock, rap and lot of other stuff. I want some tight clean bass that will hit hard and also sound good at the lower levels.. 1500 watt rms, though I'll probably won't need all that.
10" or 12"?
-js1
js1
js1
LA CA
js1
