3in. vs. 4in. coils
The Adassa ADA-SPL18-1 has a 4" coil and 6 spiders and a 660oz we have had no problen with it.The 4" will kake more power
Heres a 4" coil for the first Digital Designs 9917
The coil that came out of my Destroyer looked just like that only was a hair smaller diameter waise, but the coil out of the CSP was alot shorter than that...Ill see if I can find a camera this afternoon
Also notice that not all 4" coils stack up one against each other in windings/material.
One thing I have nowticed in dealing with Death Penality recones is that .... as far as I can tell ... the D1 coils use a larger diameter wire than the D2s which means more winds to achieve the same coil height...is that a factor in your pictures?... just curious
and you provided not one useful piece of info, all you did was post a pic of your garbage speaker.. all ive seen from yuo is borderline product pushing anyhow, you and your equipment=trash.
Hey you have a lot of mouth on a forum i'm not Andrew you come and talk like that to people that come on the forum and the mods let it happen all the time. Its cool i'm not going to get into that bullshit with you say what you want //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
^^^It appears to be something holding the rod so it doesn't bang against the basket and motor.If you look at the motor it has a piece of black material between it as well.
As for the coil's DevilDriver was right if all factors are equal the 4" would have more winding in the gap thus increasing power handling.But you also have to account for other varibles as well.
Seattle206
Seattle206
seattle
J31Rob
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
