32 ohm load question
Hey, so I'm looking at purchasing these MB Quart 6 1/2's for my dodge dakota.
My problem is that these are not your typical 2/4/8 ohm speakers. They are 32 ohms! They are rated for 75watts RMS. My 4 channel amp is rated at 4x200watts RMS at 4ohms. My question is first with such high resistance will my amp go into protection mode? And second if my math is correct (which it's probably not) will the amp only provide 25watts RMS at 32ohms? I really want these speakers to work because they are the highest quality in my price range. Any help would be much appreciated.
Thanks,
Nate
From that very same link you posted, it seems that they are 4 Ohm speakers.
General Features:
6-1/2" Premium Series Coaxial Car Speakers
Power Handling:
Peak: 300 watts per pair / 150 watts each
RMS: 150 watts per pair / 75 watts each
Composite cone with butyl rubber surround
Low resonant ABS composite basket
Phase plug with voice coil collar
Composite grill and high energy magnet
Spring loaded speaker terminals for easy install
4 Ohms impedance
1-1/2" (40mm) Titanium WideSphere tweeters
Frequency Response: 38-32,000 Hz
Sensitivity: 89dB
Authorized Internet Dealer
1-year Manufacturer's Warranty
Hmmm very good point haha but Click the features and specs tab
Speaker Specifications
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Inverted Dome
Tweeter Size 1-1/2"
Tweeter Composition Titanium
Woofer Composition Carbon Composite
Woofer Surround Butyl Rubber
Peak Power Handling 300 watts
RMS Power Handling 150 watts
Sensitivity 89 dB
Frequency Response 38 - 32,000 Hz
Impedance (Per Voice Coil) 32 ohms
Shallow Mount Installation No
Top-Mount Depth 2-1/2"
Speaker Grilles Yes
Does that mean it has multiple voice coils in series to equal 4 ohm?
Speaker Size 6-1/2"
Design 2-way
Tweeter Size 1-1/2"
Sensitivity 89 dB
Speaker Grilles Yes
Does that mean it has multiple voice coils in series?
series wiring would double impedance. that has to be a typo..
Aha most likely I was kinda baffled by that. But thanks anyways everyone. I guess these are going to work just fine then. That makes me feel retarded lol and sorry parallel wiring is what I meant to say //content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
I Look forward to trolling around here and reading up on your wisdom ha
Nate88
Nate88
Fort Collins, CO
Nate88
