300 amp alternator Ford 4.6L excessive amperage
Ryan shaw
300 amp alternator for a Ford 4.6L by excessive amperage
300 amps, 190 idle
275 shipped
shipping included
376
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
118
321
Ryan shaw
Ryan shaw
Boulder, CO
GrandSKARquis
