Krimsonviper
I'm using a DMM(Digital Multi-Meter) to tune my amps so I don't blow my speakers. The volts on that they're suppose to be at are 17.3 @ 4 ohms on each channel for the 300/4 and 49 @ 4 ohms for the 600/1 when the volume is 3/4 max. If I'm understanding this correctly, if my sub (12w6v3) is rated at 600 watt RMS, my sub won't blow, correct? My front components are rated at 70 watts and rears are 60 RMS. If I calculate this correctly, my channels from the amp are 75 watts, so the scaled back gains in volt translation should be 16.26 fronts and 13.84 rears? Or should I still listen and watch for distortion? First time really tuning a system correctly and I'd hate for my equipment to get hurt here.
I came up with these numbers by dividing my speaker's RMS by the amps RMS, assuming that it's 75 watts at 17.3 volts. I took the number I received and then multiplied that number by 17.3, effectively finding the percentage of power difference in volts.
Another question that I have is that I feel like my 300/4 is running hot, almost too hot to touch. Thermal has never kicked in, even when running it at about 60-66% percent full volume for 5+ hours. I don't believe it's a ground or power issue because my 600/1 is just warm. Same ground point, same size power and ground wire and the point has been sanded to bare metal. I never had this issue with my old 300/4v2 from back in the day and the shop who sold it too me says this amp usually runs this way, so long as thermal never kicks in. Should I be worried? What could the issue be?
Do you need more equipment info?
