3 preouts...
Rear fills aren't always necessary if you have a good setup up front, like kick panels with plenty of power to the speaks, but rear fills might be a good idea. You could probably get away with just powering them w/ the HU though
The imaging would be way off and would require a time correction. Not to mention the crossover wiring would be way long.
Just use them for the front and use the Front channel to setup the components.
They include a rear one for a set of Rear speakers!
is there a specific place that would make the tweets sound the best?
Depends on the vehicle. Usually try the A pillar, the door panels, etc...just experiment with it and see what sounds best. I would install the comps before buying rears and then if it doesn't sound right w/o rears, buy them then
BIGsherm7272
Tampa, FL
dkmesa
