Sold 3 pHOENIX gOLD xENON 200.2 AMPS....GREAT POWER FOR THE MONEY
gentlejax
These were the last of the good amps made by PG. Original run was bad but they got that fixed and these turned out to be every bit as good as any of the legendary PG stuff from the good old days.
Triple darlington ...fan cooled....high quality parts...
2 of them never been out of the box..new and complete $160 shipped
1 of them used for a short time..looks new..& complete $145 shipped
specs:
400 Watt Power Amplifier
Xe.load™: optimized for any impedance load
Xe.tune™: 24dB Linkwitz-Riley high and low pass crossovers
Xe.flow™: variable thermal feedback controlled fans
Tried and true triple Darlington output stage
Buffered RCA full range thru output
Remote Monitoring Display (RMD) port
Low Pass Level control ready (LPL-44)
200W x 2 (4-1 ohm stereo)
400W x 1 (8-2 ohm bridged)
Built-in Crossovers
Optional Remote Voltage Display
Optional Remote Low-Pass Level Control
Variable input sensitivty
0 - 18dB Bass Boost at 45Hz
CEA-2006 Compliant
High end Sanken capacitors....1 OHM STABLE!!!
I will get some pics today...I was busy this weekend....2 of them are new ...1 is used..all on ebay now......
excellent amps for bargain price.
yep too bad...
I AM working on pics still...had to admit the wife in the hospital yesterday to monitor her blood pressure..as she is pregnant and we thought they were going to induce...
so...I am going to get them this morning..
going to go and get it out of the car to take pics....but as a teaser here is some from the manual...
Sound Quality:
During the electrical design process, some of the
finest parts were chosen to achieve the finest sound
quality customers expect from a Phoenix Gold amplifier.
Multiple small capacitors are located throughout the
PCB layout. By using multiple smaller capacitors in
parallel, this lowers the effective ESR of the circuit,
(This is the same concept as if you were to parallel
multiple subwoofers to achieve a lower impedance.)
Since multiple small caps will have a lower ESR this
will make them able to deliver energy much quicker
than a few large caps. The end result is tighter, more
accurate, and dynamic bass. The output stage
on the two and four channel models are loaded
with audiophile 150 Volt 15 amp Sanken output
transistors. Sanken output transistors are used due to
their high level of specification and amazing bandwidth
of 60MHz. Each model of the amplifier design is
critically listened to and evaluated by Phoenix Gold
Engineering and Product staff for hours to ensure the
sound quality is as close as possible to our in house
master reference audio system
gentlejax
gentlejax
Bossier City, La.
gentlejax
