3 jl audio 10w7 box design
shawn donkey
audio nut
ok after reading the forums its clear that some of you are really smart/talented. so maybe i could impose on some of you! I have 3 jl10w7 subs each powered by there own 500/1v2 amp. i currently run them in a sealed encloser. each has there own sealed chamber. i have lots of room so can anyone help me design a vented box? i have no exp in maken vented enclosers. this is in a gmc yukon.
if this box will be common chamber you need to get one amp to run all 3
i dont know much about vented boxes but... does a vented box have to have all three woofers in the same chamber? also i have my amps set up as 1 master 2 slave amps all running off the sound processing of the master amp each amp was tuned with a meter for exact input sens. so they should act like 1 amp. as im told by jl audio that is. i tried to run these 3 w"s on one channel at 1 ohm on a 1500 watt amp and it sounded like crap.
shawn donkey
audio nut
shawn donkey
ketchikan alaska
shawn donkey
