Sold 3 DD-9512's FS
TnT_Sounds
profiling gets **** done!
I have 3 9512 "g" motor woofers. One is BNIB never used or seen power. The other 2 have fresh recones from Eagle on ROE that have never been used. ALL are D4 coils. I removed the DD decal on the BNIB one because I was intending on mounting the woofers off-center and I was going to lay down new decals to be straight to the eye.
$450 + shipping for BNIB
$400 + shipping (each) for the 2 reconed
The woofer on the far left is the BNIB //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
DD only has ONE kind of surround! The "wide"-"tall" surround is the new, and the small is old. That is the diff. DD switched to the tall surround around the end of april. Same 80mm excursion on the 35's and 95's! Bump for a good seller!
Actually. The new surround was made for the DD Z sub. But then DD started using them on all there upper end subs... You can still get the smaller surround if you need it to match your older subs.
TnT_Sounds
TnT_Sounds
Colorado
arntsmag
BP1Fanatic
BP1Fanatic
