3 cube sealed to much for 12" l7?
ok well the thing is i used the plans in the box section for 3 cubes @ 35 hz , but the port pieces dont quite fit right , like its the long port piece then short one, but it only fits the OTHER way, with short piece, then long piece
will it make a difference? i mean its the same port length and everything, just the other way around.... is this alright or will it totally screw up the tuning frequency?
ok here i looked at the plans again and it dosent make sence
my.php
here is the link http://img23.imageshack.us/my.php?image=3cubes35hz465sqin4wj.png
look at the plans, it says the port piece that comes from the front is 8.75" but its extremly longer than the second port piece that is 13.75" do you think he just mixed up the two numbers ? thats what i mean when i say it dosent fit when you try to do it like the plan says
edit:: oohhh ok i get it, the port pieces just arnt drawn to specs , i get it, short piece first then the long piece that follows along the backside of the box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Twistid
Twistid
in a space out of sound
Twistid
