3 8w7's or 3 10w6v2's??
FSUNole17
hey, i am considering a new system to be powered by an orion 1200d amp. I want opinions on what would be OVERALL better in terms of sq and spl. the w7s would run at 1ohm getting each sub 400 watts rms, while the w6v2 would only get say aorund 300-350 apiece with an overall load of 2.67 ohm. the install would be in a sealed box, but the w7's would only have abotu 0.7 ^3 ft of airspace and they like around 0.9^3 ft while the w6v2's like right at 0.7^3 ft. all these factors considered, which do u think would be the best. my MAIN goal is great sq, but having tons of spl wouldnt hurt either //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
first of all .. that 1200d puts out 1200@ 1 ohm, 725@2 ohm... and 425@4 ohm.. how do you figure you'll see 900-1050 @ 2.67 ohms?? you'll actually be around 650 watts at 2.67 ohms.. which will give each w6v2 about 217 watts each.. far from optimal... i would NOT go that way.. it would be a waste of subs/amp...
why don't you get 2 jl w6v2 12's? that would put you at 1 ohm and 600 watts each.. which i guarantee will out beat the 3 10's only seeing 217 a piece
and the 8w7's will be alot better than the 3 10w6v2's with your amp
my fault, i was misinformed on the power at 2.67 ohms..... and ya the 2 12w6v2's sound liek a great idea as well, so now let me say this.... it comes down to 2 12w6v2's or 3 8w7's ........ NOW which would ya pick!? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
put 'em in your cabin if you want spl -- you can't do that with 10s!
Tell that to Nate Munson.
As for the W7/W6v2 debate, I thought the W7 had the edge in output (obviously), but I liked the overall sound of the 'W6v2 better. I would go with several of those.
FSUNole17
FSUNole17
franklin, tn
audioholic
