3 12's in a subaru
im wondering how did you wire the subs to 2 800 bazooka amps
i have two of the subs going to one amp in parallel and the other sub going to the other amp in parallel..... so 2 to 1 and 1 to 1
plus i was thinking about sealing the sides off with a whole wall
yeah port it and don't forget to turn the box around so that the subs are facing the front //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif be funny if you sealed off the sides with the subs facing the rear haha lulz
Ok, i'll say it.....................you need to design a box that fits nicely in the car. You have plenty of room to work with, make it subs up and port back. Also, i see no bracing in the build pics, you should add bracing or put braces in your next box. You should do four subs on the next box if you are going to run two amps. The cuts and work on this box look good, so you have the skill and tools to do a cleaner build. How does this box sound?
the box sounds really good actually... to me at least... i would like to do something a little diffeent but havent figured out what yet....
wire it 1 amp to 3 sets of coils, one set on each of 3 subs //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
1 amp does positive - negative across the top set, then the other amp across the bottom
"Ported Box Volume (cubic feet) 1.75 - 2.25 "
I had one in a 2.22 cube box tuned to 33hz and it was pretty nice.
Box is wayy to big for only 3 and being sealed.
Sealed should be like 1.5 cubes each sub. So you could add 3 more and keep it sealed or add another one and port it. In the picture I see 4 boxes.
Holy Hell are you hiding small children in there? You need to cut that into a pyramid. WAY too big.
hansk
hansk
ATL
hansk
NorthFramingham
    Jun 30, 2026
