3 12" Diamond Audio D3 vs 2 12" Kicker L7
  • 2
Flipp153
Bass addict in training
Hey hows it going? I got 3 12" diamond audio d3s in a independently sealed 1.2 cu.ft. per chamber box powered by an older power fosgate 1000bd amp in the back of my 03' dodge dakota ext cab. I like the way they sound but I find myself wanting a little more sometimes. I was thinking of getting two kicker l7s in a sealed box the same size of the triple 12" box. So like 1.8 cu. Ft. per l7. Any advice or recommendations? Stick with the 3 diamond audios or 2 kicker l7s with bigger chambers. Thanks.
Well l7s are crap ..and like huge ported enclosures...a proper ported box for a pair of 12s would be like 5.5-6 cubes..and I wouldnt recommend them sealed...id go for a pair of 12s ported ....maybe a pair of sundown audio sa 12s or something in that power class..will be wayyy louder than the setup u have or are wanting
Thanks for the fast response. I'll look into those subs you mentioned. What would be a good sealed enclosure sub? I usually prefer the sound I get out of sealed enclosures. From my experience sealed seemed tighter although ported did sound louder.
The sundowns will still do well sealed as will the sundown e series..and uf ur set in sealed buikd ur own box it will sound better than the cheap thin prefab sealed boxes
Alright cool. I seen the sundowns going for $199.99. Is that good? Also, do you know by chance know what would be a good size box for them? Thanks a lot for all the help.
Yea thats about right ..they can be had for cheaper sometimes. .just check around on diff sites..and the reccomended sealed box will be on the sundown site..id say probably around 1.5-1 75 per sub .just off the top of my head..
I had some of theyre subs and components in the past in the late 90s. They were nothing special and were expensive. I had better luck with Bostons...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
222
Flipp153
Flipp153
Hammond, in.
NASTY08IMPALA
