2x12 in L7 dual 4ohm Solo-barics to APSM 1500 wiring diagram?
  • 4
Title says it all. Was hoping someone knew the best way to wire this so that it won't trip my box fuses. I asked about what I should get to power them and apparently 1 APSM 1500 would be my best budget option. My friend who set it up for me in the first place is going to help me, and he knows what he is doing, but I'd at least like to come to the table with something to offer or a direction I'd like to go with the wiring. They are the 1500 watt (750 watt rms) L7 Solo-barics with the dual 4ohm coils. Thanks folks.
http://www.vminnovations.com/Product_16149/Audiopipe-APSM-1500-1500-Watt-Mono-Mini-Amplifier-.html
http://www.sonicelectronix.com/item_2133_Kicker-04S12L74.html
Yes, that is what I was asking. Thanks. I also found this video on youtube that explained it better, but I was wondering, what gauge wiring should I use wiring the woofers together?
Tell your friend to run it @ 1 ohm in parallel, if he knows about car audio he'll know what to do.
As far as wire, it depends on how far you'll be running it. Assuming your amp is in your trunk, I'd say at least 4ga.
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
380
596
976
acesrhigh
acesrhigh
Portsmouth, OH - United States
acesrhigh
