2x 12" P2 subs with amps & enclosure
thej63
2x 12" Punch P2 Subs
4 Ohm, 200W RMS, 400W Peak
Q logic enclosure
rockford fosgate p3001 amplifier
mono subwoofer car amplifier
150 watts RMS x 1 at 4 ohms (300 watts RMS x 1 at 2 ohms)
variable low- and high-pass filters (40-400 Hz, 12 dB/octave)
variable Punch Bass boost with wired remote (0-18 dB at 45 Hz)
kenwood KAC-8402
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (90 watts x 4 at 2 ohms)
180 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
front channel high-pass filters (50-200 Hz at 12 dB per octave), rear channel high- and low-pass filters (50-200 Hz with 12 dB/octave high-pass and 18 dB/octave low pass)
bass boost (6 dB at 90 Hz), channels 3 and 4
Box has several cosmetic blemishes 7/10
fosgate amp on the top has scuffs and a crack in the plastic on the top 6/10
kenwood has minor blemishes 9/10
subs are 10/10
Everything worked perfectly when disconnected. The car that this was in met an untimely end and I didn't want to waste my time pulling everything apart to disconnect wiring so I cut the cords to the box to remove it. It is currently taking up WAY too much space in the back of my jeep and needs to go so I can put a much smaller setup in there.
looking for $250 OBO
If you would like the components shipped, message me and we can work something out. I am willing to pull this apart ONLY if the purchase is for everything minus the box. I will not split this up in several transactions as I want it gone. Local pickup is preferred.
If you would like bigger images this is the link to my flickr album with them
Mis-understood the wording in the rules section. Having the second sentence in point #2 makes it read as if a photo of my username and date are all that are needed and that it's just making reference to the point above (that item photos are still needed). Either way I just walked out to my car and shot a new image with today's date. Posted the image a little larger since the sun made my writing a little harder to see.
- All posting must contain a picture of every item listed in the thread. No pictures and your thread will be deleted without warning.
- You must post pictures with username and date (on a piece of paper, a digital version will not be suffecient) unless you have sold to at least 10 people on this forum with positive results. Pictures of the actual item in your possession is still required.
thej63
thej63
Jenkintown, PA
thej63
