2ch amp 4 speakers
Assuming your door speakers are 4ohms; Just wire the left front and left rear speakers in parallel to channel 1 and the right front and right rear speakers to channel 2 for a nominal 2ohm load per channel.
And you would NOT want to wire both the front speakers to one channel and both the rear speakers to the other channel because you would lose stereo sound.
they are 2 ohm infinitys
Still not a problem.
Wire them in series instead of parallel for a final 4ohm load.
From a brief search it appears that amplifier is rated for 200w x 2 @ 4ohms....even if it's overrated some that's still more than enough power.
You're still good to go.
dbolemiss
dbolemiss
New Iberia,LA
dbolemiss
