28"inches
90 fox body mustang... 347 stroker, paxton super charger, 411 rear end, trick and flow heads, hooker headers, msd poer everything, 2800 stall converter....
1) your not running eights in the quarter with that setup, especially with 300 lbs of stereo equipment, maybe with the twin turbo setup on 30 lbs of boost
2) its trick flow heads
3)8's with a 411 rearend? an 8.8 rear at that?
4) which paxton were u running?
5) your full of shit
1) your not running eights in the quarter with that setup, especially with 300 lbs of stereo equipment, maybe with the twin turbo setup on 30 lbs of boost2) its trick flow heads
hehe... pwnd (untill proven otherwise) //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i'll tell you what come to atlanta and i'll take you for a spin. i promise you, you'll have whiplash once you get out of my car.
paxton novi 2000 27 psi
some more info for the jackass aove.... straight hater!
Three Spoke Polished Aluminum Wheels
EdelBrock Intake Manifold
Saleen Style Wing
4:11 Gears
BBK 65MM Throttle Body and EGR Spacer
AutoPower 4 PT Roll Bar
Crank Roller Rocker Arms - 1.7 Ratio
Custom Grind Cam 527 Lift 216 Duration 112 Center
24 LB/HR Fuel Injectors
MAC 1.5 Equal Length Shorty Headers
CCM Caster/Camber Adjustable Plates
Vortech C&L 73MM Mass Air Meter
BBK Adjustable Fuel Pressure Regulator/Gauge
KYG B-2 Gas Struts/Shocks
DynoMax/BBK 2.5 Cat Back Exhaust
BBK Specific Rate 1.5 in Lowering Springs
155 LPH Fuel Pump
BBK Underdrive Pulleys
BBK PolyUrethane Suspension Bushings
BBK OFFSET Poly Steering Bushings
BBK 23 Tooth Speedometer Gear
Ram Air Induction (6" Duct) K&N Filter
180 Degree Hi Flow Thermostat
you say in an earlier post you have a 150 shot on th 95, dont see that in the pics, no saleen wing on either car, 3 spoke wheels?? its okay i was 16 before, you'll get over the lying for approval phase
yea ill come to atlanta to race you? im a crab, look through my posts and look through all the negativity you spew in yours, im surprised your not banned, well you probably were and just rergistered.
jerryrobinson
jerryrobinson
chicago IL
Tonyguy
BP1Fanatic
BP1Fanatic
