2500D drivers seat attenuation.
60ndown
i want to install a rotary dial to control volume on the 'beast' while the carpets are up, even if i dont use it in the end , i want to install it just in case. where do i get one or do i have to build it?
If it's a quality pot, it shouldn't be crunchy or have noise. It's a passive item, so that should eliminate the possibility of weird induced noises, alternator whines, loops, etc.
Simple unit, really; Note that this will trim the entire signal from whatever RCA you use with it. This is different from a remote gain control in that it will attenuate to 0 or restore to full whatever voltage is coming from the RCA; likely the headunit outs, whereas a gain control leaves the original signal intact, and adjusts it at the amplifier end.
I have 1 of those NV-22's. But I like my other babies better!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
60ndown
60ndown
ca
DBfan187
NorthFramingham
    Jun 30, 2026
