$250 for a big mono amp. ( no junk plz )
brian84corvette
I have re sx 18 d2
currently using hifonics bxi1206d - its ok.
but now its feeling like not enough power.
if you offer up lanzar / kole = I will kick you in the shins.
wanting to find 1800w or more up to 3K if its right,
as I can toss the sx and get a tc/storm or dd 18" that will handle 3K properly.
but I know I aint gona find it for $250
BUT
I still need to try out the sx on some cheep power.
feeding it its rms is good only for so long,
im needing more now
thanks.
$250 is avalable to spend.
I have paypal, but not loaded at the moment
incase I need to put in a little extra for the right amp.
whatcha got?
realley ? I had a guy at the swap today trying to pawn a kole on me for like $300 nib.
I guess about 2K coming out of the "5500" model sounds about believable.
so your saying that the newish big kole's arnt total junk ?
those were 16v results....
here are 12v results
I did a little more testing with the Kole Audio Phanatik PH1-5500D using a better 12 volt power supply(Power Master d3100). With the voltage starting at 14.2 volts and dropping to 11.5 volts, the amp made 2064 watts. This was at a 1.12 impedance rise.
wow. im impressed by the kole 5500 then.
I will cease fire on kole for the time being.
thanks for those #s - I had no idea.
I am still mad at lanzar tho. I popped a pair of 10's from them
giving them half the rms - in 7 minutes of play time.
so lanzar gets to stay on my I hate you list.
old lanzar's are amazing! Opti series //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
X2 and their not really that old
the OP hasnt a clue that lanzar sells boards to other companys including some top name amps.noob //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
^ this is a true statment.
ive never actually seen in person an opti or got to hear it.
maby its good, im wary of the lanzar brand name tho.
wow. im impressed by the kole 5500 then.I will cease fire on kole for the time being.
what series were they because they make stuff across the board very cheap to very bad ***
^ this is a true statment.ive never actually seen in person an opti or got to hear it.
in your situation id try one of these
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=20355
brian84corvette
brian84corvette
coral springs FL.
adrian1185
