220A Iraggi load tested 74A :(
Kryptonitewhite
I went to Advanced Auto, their load test doesnt do ampers, 1st with car off all electric off:
advanced auto print out
battery test 12.82V
measured 1256 CCA
rated 758 CCA
Temp 21deg F
While stating:
starter voltage 11.74V
0.0A time
625mS
dipped to 10V
running:
Charging system test
no load 14.62V ---A
loaded 15.58V ---A
ripple 37mV
I haven't pooped today. Am I gonna die?
I think you'll be fine bro...I haven't pooped either. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif And I am feeling rather spry I might add. //content.invisioncic.com/y282845/emoticons/boink.gif.91933e72f927f2cefc79aff02573090c.gif
What a relief. I was scurred there for a minute.
that autometer is very inaccurate bro
they have to bench test it to present a load on it to get an accurate reading
( used to manage Checkers/oreilly )
so nothing short of pulling the alt and havin her strapped down? Its very tough getting it out, and it's my only transportation, so pulling it then running around is next to impossible, and if I broke somethin in the process, I got no wheelz till i can get it fixed. Just assume it's OK?
I never expected to use as much of my available power as I am otherwise Id have gotten dual alts to begin with. This Iraggi failed once, they went out of business, so i had to have it fixed locally. I got lucky the local shop had a tension spring available that fit. Since it's been repaired, its made a little noise hence my worry and testing. The spring that pushes the brush against the... comutator? Thats what went out, the top plastic assembly/housing for it was replaced. Snapped old off, snapped new in.
Dom is oob... prolly a good thing too lol
Sorry Kman it will prolly do as a stock alt for awhile but I bet it is fubar... for about 125-175 you can have it rebuilt at some shop around you ( we have several places here that do it )
my only local shop could barely repair it when it went bad, they wont re-wind...they cant do HO, only multiple set ups and cant even help with mounting or brackets //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
damnitman!
I had a choice of more power at idle, inbetween, or more peak. The smallest alt is rated 160A-200A at idle 220A peak, the biggest alt is rated 160A-180A at idle 300A peak. I chose 200A idle 220A peak.
I was idling. I should have gotten a minimum of 160A and up to 200A at idle.
Ive had Dominic Irragi on my Facebook since I started my research, he deleted it and started a new one. I added him, bet he doesnt accept! I sent yet another email last nite, we will see
bad alt? good alt?‏
1/29/11
Emailed him again last nite:
dominick@tds.net
Sent: Sat 1/29/11 9:21 PM
To: dominick@tds.net
Hotmail Active Viewadvanced auto CCA voltage.AVI
Go to YouTube
Play video
advanced auto print out battery test 12.82V measured 1256 CCA rated 758 CCA Temp 21deg F starter voltage 11.74V 0.0A time 625mS dipped to 10V Charging system test no load 14.62V loaded 15.58V…
00:02:50
Added on 1/29/11
Loading video preview from YouTubeThere was a problem connecting to YouTube. This video may not exist or it may only play on YouTube. Try going to their website: YouTube - oreilley 74A load.AVI
I just went to have my 160@idle 220 peak tested, it was load tested as 74A. It is rated 160-200A @ idle, 220A peak. Test no good? I want to make sure the Iraggi works as it should before adding a 2nd alt.
Thanks!
battery test 12.82V
measured 1256 CCA
rated 758 CCA
Temp 21deg F
While stating:
0.0A time
625mS
dipped to 10V
running:
no load 14.62V ---A
loaded 15.58V ---A
ripple 37mV
YouTube - advanced auto CCA voltage.AVI
Went to O'Reilley's
Load test 74A
Kryptonitewhite
Kryptonitewhite
soo foo sd
Kryptonitewhite
