2200x2rms@.5ohms or 4400x1rms@1ohms
lil_italy773
Team D.O.A
i have a hk-802sx, i have 4 L7 15s D2 and can wire 2 Parallel/Parallel for .5ohms witch the amp can do 2200wrms x 2 or i can leave the current way all 4 wired Series/Parallel @ 1ohm. i was wanting to try it at .5ohms but b4 i take all the subs out and rewire i thought id ask and see what ppls thoughts on this, pros or cons???.. any input would be great.
wire them to 1 ohm then bridge... and if your really brave try .25 bridged (yes, .175 on each channel) mine never went into protect and i did all kinds of crazy shit with it
But if that amp drops much below the 12volt range it will start on fire, or atleast go up in smoke!!
i had mine in a pontiac bonnivile with the stock alt, stock bat, some cheap used wet cell batt in the back, and 1 run of 0/1 to the trunk
voltage dropped to low 11's high 10's
i know i gave the amp hell but it never went into protect on me once, thing was a tank
and to the op: i understand completely, if you dont wanna drop your amp that low i dont blame you... but just know if your ever trying to burp it or anything, the amp can take it imo...
lil_italy773
Team D.O.A
lil_italy773
Hialeah, FL/dade county
lil_italy773
