21" 6" voice coil sub
2000LaDe
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=294-690&CFID=11982445&CFTOKEN=34419022
this might have already been posted but i have never seen it. so im posting again.
3,000 watt continuous program power capacity
6" copper voice coil wound on glass fiber former
30-1,000 Hz response
95 dB sensitivity
60 mm peak-to-peak excursion before damage
Neodymium ring magnet allows a very high force factor and linear excursion
Double silicone spider with optimized compliance
Ventilated voice coil gap for reduced power compression
Aluminum demodulating ring decreases distortion
Undercut pole piece
Triple roll surround
Water-resistant cone coating
There's certainly nothing wrong with stamped frames. Given a desired thickness, they would be a lot stronger than any grade aluminum that's out there. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
2000LaDe
2000LaDe
Lafayette, IN
2000LaDe
michigan born
    May 14, 2026
michigan born
    May 14, 2026
